SlowWhiteV6
05-23-2005, 02:56 AM
Im going to be building a sub box for my car and im going to be running two audiobahn 12s but im not sure how to go about doing this, this will be my first box ive built so I have a few questions.... here are the specs on the subs
PHAT 2 Foam Surround
* Non-Pressed, Non-Transfer Paper Cone
* KM3 Coated for Virtually No Cone Distortion
* Single 4 Ohm Voice Coil
* Multi-connect Lug Lock Terminals
* Magnet Weight: 80 oz.
* Mounting Depth: 5 5/8"
* Hole Cutout: 11 1/2"
* Outer Diameter: 12 3/4"
* rec. selaed box dims: 0.75 - 2.00 cu.ft.
* rec. ported box dims: 1.30 - 3.20 cu.ft.
* sensitivity: 92.8 dB
* frequency response: 26-1,000 Hz
* recommendes RMS power: 550W
* peak power handling: 1100W
* impedance: 4 ohms
should i go for the top of the range of the sealed box dims? or maybe for the mid? and when i find out what size boxes i need to make do i need to figure in the amount of space the sub will take up inside the box? any help would be great
* impedance: 4 ohms
