Fan... and overheating...
BlackHawkA4
05-18-2005, 04:03 PM
My fan dosn't seem to be turning on. I orignally check this and it was turning on when i initialy turned the car on. I checked this because my engine temp is getting 220 plus in stop and go traffic. So now I'm looking at it and it dosn't turn on. And now I'm seeing a leak, which was smoking when I opened the hood to see if my fan was working, whatever was leaking was ontop of the right manifold cover.
masiroc566
05-18-2005, 04:18 PM
Check your fuses first!!
BlackHawkA4
05-18-2005, 04:24 PM
The fan turns on when I put the AC on. It just dosnt turn on or stay on when driving.
89_Irocz
05-20-2005, 07:24 PM
On the right Head above the starter, is the Fan switch. It is a little sensor that when the engine reaches 220, It grounds the fan to the engine witch turns on your fan. It's only about $10. If bad or broken it "CAN" leak Good luck!!!
