1997 Camaro SS For Sale
1997 Camaro SS For Sale *Reduced*
1997 Camaro SS Build #25
350ci 6 speed manual
Reduced to $5500.00 7/7/05
Autotrader
94,000 miles, it was a blast to drive, I really hate to sell it but it has to go. I’m concentrating on a road racing Camaro, so I need the space and money. Car has low build number. It has a 1996 Camaro/Z28 Ram Air box and Analog odometer which makes it very rare. Car has a spun Rod Bearing due to failed oil pump. Car will start. GM sells a LT1 350 4 bolt short block for $1500.00 but they are hard to find. For serious buyers I will advise where one can be picked up. Suspension is set up perfect for handling. All accessories work perfect. Super Cold AC. Body is straight never wrecked or smoked in, still has the leather smell. Paint in good/great condition, small chips in the front not bad for a 94,000 mile car. I WILL NOT PART OR SEPARATE
Standard Options
Cruise Control
Remote hatch Release
Fog Lamps (removed due to constant rock breakage, I still have originals)
Power Door Locks
Power Windows
Grey Leather Interior – 30th Anniversary embossed in headrest
Power Mirrors
6-way Power Driver seat
Factory Alarm
T-Tops with locks and covers
Factory Bose AM/FM CD Player
Rear Window Defogger
Body Side Molding
Monochromatic Paint (Mirrors and Roof are same color as car - RARE)
SLP Options
Light weight Composite RAM AIR hood
Rear Decklid Spoiler
SS Plaque
Tier II Bilstein Suspension System (Stiffer Springs and revalved Bilstein shocks)
Hurst 6 Speed
Engine Cooler
Torsen Limited Slip differential
AAM differential Cover
SS Floor Mats
SS car cover
Engine
350ci 4 bolt main. (New short block at 52K miles)
LT4 hotcam
GMPP 1.6 Roller Rockers
Mild ported LT1 heads
Edelbrock Headers
Percy header gaskets (never leaks)
Retuned PCM
Dynomax Exhaust
Brand New Water Pump at 80k miles
Brand new optispark (distributor) at 80K Miles
New Fuel Pump at 52K Miles
Misc – currently on car
SLP Lightweight Clutch and Pressure Plate (no slippage)
Kumho MX 275/40/17 tires plenty of tread
All supporting Documentation, Window sticker and receipts included.
Please advise of any additional questions. Or more pictures.
Autotrader
Standard Options
Cruise Control
Power Door Locks
Power Windows
Power Mirrors
Factory Alarm
Body Side Molding
SLP Options
SS Plaque
Hurst 6 Speed
Engine Cooler
SS Floor Mats
SS car cover
Engine
LT4 hotcam
Edelbrock Headers
Retuned PCM
Dynomax Exhaust
Re: 1997 Camaro SS For Sale
It would at the minimum require a bottom end rebuild. Typicly $1000 on up depending on the extent of mods parts etc anything that may be reused on existing shortblock (Crank rods etc..) I do not have the engine apart so i do not the extent of the damage, but it is a rod knock. I know of a dealership which still has GM 4bolt lt1 short blocks for about $1500. The dificulty is realitive to any type of engine work you may have done in the past.
ok, so it wont necessarily NEED the new block???
Also, I'm going to be going on vacation to Arizona at the end of June. I'll be in Scottsdale (i believe about 40 minutes away from you) so if you still have the car then, i'd definitely like to come see it.
Blue89Bird how much do you want for it
Originally Posted by Tom 97ss #25
Sorry I forgot to post it, i updated it. $7500.00 OBO
Originally Posted by Blue89Bird
well...LT1 SS's go for about 8-8500 in decent running shape, I got 8k for mine. Yours needs about 2k of work, so I'll offer 5500.
This is the first day so I'd like to give a while.
The best I can do is accept my payoff of $11,323 + your car.
Specifics:
2001 CAMARO SS
AUTOMATIC
41,400 miles
Production number: Of 1,956 Units made:
11U Light Pewter Metallic & Ebony Congo Cloth Interior - 378 units built.
In sparkling like brand new showcar OEM condition.
For pix see: http://pg.photos.yahoo.com/ph/eddie...roxus/my_photos
VIDEO CLIP: http://s50.yousendit.com/d.aspx?id=3...L3QPNJYETBIKBP
You may contact me in North Alabama. Eddie (256) 381 5902 or eddierox@juno.com.
Yahoo Messenger: eddieroxus
Specifics:
2001 CAMARO SS
AUTOMATIC
41,400 miles
Specifics:
2001 CAMARO SS
AUTOMATIC
41,400 miles
Specifics:
2001 CAMARO SS
AUTOMATIC
41,400 miles
