M6 pedals question. T56 conversion people inside please.
Old May 15, 2005 | 06:33 PM
madwolf's Avatar
I am missing the left switch in this picture. What exactly is it for and what does it connect to?
Thanks.
Old May 15, 2005 | 10:47 PM
chevelles101's Avatar
Re: M6 pedals question. T56 conversion people inside please.
I'm not 100% sure but I believe that is to disengage the cruise control with the clutch
Old May 15, 2005 | 10:50 PM
madwolf's Avatar
Yep, that's what it is. I figured it out shortly after. Thanks.
Old May 16, 2005 | 09:11 AM
Chris 96 WS6's Avatar
Yep and you don't really need it to be honest. I'm not sure where it wires up because my cruise is broken anyway. The starter interrupt switch is vastly more important IMO.
Old May 16, 2005 | 09:15 AM
madwolf's Avatar
This switch is supposed to be in series with the other cruise control switch from the brake pedal.
The second switch on automatics is for TCC/Shift interrupt (which won't be used with a T56), so you would have to cut the connector and splice into the other connector's wires. (that is if you want this feature)
Old May 17, 2005 | 01:36 AM
MEAN LT1's Avatar
Good luck with the wireing. Shouldnt be too hard. I just jumped the yellow and blk wire togeather to start the car. No need for a clutch switch unless you really want it.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Queens94z28
Dec 20, 2014 09:11 PM
Z28Wilson
Aug 1, 2002 04:27 PM
