where to buy steal braided clutch line
Old May 15, 2005 | 12:44 PM
twdz28's Avatar
just like the title says... i looked at gm parts direct with no luck!!!
Old May 15, 2005 | 12:54 PM
marshall93z's Avatar
Re: where to buy steal braided clutch line
I had one made at a local shop that does Nascar stuff for $11. I used my fittings and just had them make me the right length line.
So maybe try a local hydraulic hose company that can do stuff that small.
Old May 16, 2005 | 01:58 AM
twdz28's Avatar
I'll try that, thanks!
Old Mar 2, 2006 | 09:23 PM
Firebird355's Avatar
would those companies have those roll pin fittings? oh and do the lt1 cars have the roll pin fitting on both ends like the thirdgens? I am trying to do a v8-t-5 swap in a newer s10 so i have the master out of the truck already and it has a roll pin style fitting and I know thats how the t-5 slave is...
Old Mar 2, 2006 | 09:45 PM
My Red 93Z-28's Avatar
Mine broke and I had to buy the slave and hose together from GM, they don't sell them separately. Your best bet is to hope one of the options above works for you.
Old Mar 4, 2006 | 12:54 AM
StudyTime's Avatar
Mine broke-off at the slave. We were actually able to cut it and then turn it in a lathe so it would work again. After 10 minutes, we had the roll pin back in and it was good as new... just a little shorter.
Thunder Racing sells the line if you can't find one anywhere else.
Ben T.
87Aerocoupe
Mar 20, 2015 01:23 AM
HectorM52
Jan 30, 2015 11:08 PM
Jazsun
Dec 29, 2014 12:14 PM
