T-56 leakage?
Old Oct 17, 2002 | 12:25 AM
mykal427's Avatar
T-56 leakage?
I noticed about two weeks ago that there was somekind of oil leakage coming from the rear of my 00' SS? I didn't think much of it figuring it was coming from the back differential and I had just recently changed the gear oil from there. But when I looked the differential was perfectly dry. I noticed the oil trail was traveling along that long middle beam on the underside of the car and the oil was dripping off at the back two bolts. I thought well maybe the oil pan or filter but they two are dry as well. Then I wondered could a back seal from the T-56 be leaking? I couldn't really tell but the front part of the T-56 is dry as well.
What are your thoughts given this? I appreciate your replies/suggestions. Thank You
Old Oct 17, 2002 | 04:53 AM
TerrorDome's Avatar
took my z in for an oil filter change and the mech. told me the rear diff. was starting to leak just a tad. not sure if that's the case ,maybe have a mech look at it? leaks can be tricky to pin down i think.
Old Oct 17, 2002 | 08:05 AM
ssvegas's Avatar
yea a chevy tech guy said that my pinion seal needs to b changed...i have leakage in the back too...and i have a '00.
Old Oct 17, 2002 | 10:59 PM
mykal427's Avatar
No the rear differential is fine the seal is absolutely dry all around. The leak is dripping off the back two bolts in front of the differential. The only thing I can think of is the rear seal of the T-56 is leaking or somewhere in the rear of the transmission???
I'm not gonna drive it and check it out closer this weekend.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
GreenMonster138
Classic Engine Tech
Mar 26, 2003 02:14 PM
ryu
Mar 13, 2003 08:22 PM
VentsWoker
West South Central
Nov 17, 2002 03:29 PM
