Planning a turbo stroker need help
Old May 11, 2005 | 10:09 AM
mrz28 73/97's Avatar
As the title states I'm in the planning stages of a 383-388 turbo buildup and need some expertise/advice on the setup, this is going in a 95 Z28. All forged rotating assembly either Scat 3.75" crank & 5.85" rods or GM 3.8" 4340 crank and 5.85" rods with a forged dished piston 9.5:1 cr. Splayed billet caps and all race machine work to the block, not sure what head yet either AFR 210's or Canfields or Trick Flow LT1's with complete port/polish work done. Custom turbo hr cam & R-series lifters. High capacity oilpan/pump/pickup, ported LT4 intake 58mm tb. PTK t76 single turbo intercooled setup and necessary catback setup I'd like to run 15# on pump gas if possible. My goal is 800rwhp/825rwtq, run 9's full weight street trim.
Here's what I need assistance with, what ignition setup LTCC?; what size injectors?; what trans, G-force M6 or built turbo 350/400?; what fuel system Aeromotive?. TIA for any help or advice you can give oh this will be mostly street driven occasional track use.
Bobczar
Oct 23, 2015 11:22 AM
NewsBot
Jul 8, 2015 06:47 PM
Jmlcolorado
Jul 4, 2015 08:31 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
blac94Z
Jan 22, 2015 11:19 PM
