skipshift light turn into shiftpoint light
Purplemaroz28
05-08-2005, 03:28 PM
is there any way to set the skipshift light to come on at certain shiftpoints instead of hwo the manufacture has them set up... i have the skpshift eliminated, but it the light still comes on.. and i was just wondering if there was a way, or someone who can program the light to come on at proper shifting points.... i hate those big tachs people hang off there steering wheels and was just curiouse if it was possible to reset the light to do this... thanks steven
Joe Brodman
05-08-2005, 03:41 PM
Looking at the CAGS settings in LT1_Edit, I don't think so.
For the settings, you can adjust the following:
- Disable and Enable in MPH
- Disable and Enable in Engine Load
- Enable engine Temp
- Disable in RPM
- Disable in TPS sensor Percentage
For this to work, you would need to have a setting for enable in RPM (while using a plug-in skip-shift eliminator device of course).
You could do it reverse wise, where the light is constantly on until your shift point then goes out.........
Purplemaroz28
05-08-2005, 05:11 PM
- Disable in RPM
that would quicly get annoying but thanks for trying to help
z71camaro
05-08-2005, 06:47 PM
Just get a RPM activated switch and wire it to the light.
I've got the cheap proform. The unit is getting mounted under the dash where it can be adjusted. Haven't decided on a light to use, but its gonna be damn near invisible until its lit.
