Nitrous Tune vs Regular tune??
gabez28
05-07-2005, 03:44 PM
Hey guys I have a tune from PCM4less with the unlimited tunes option. I was curious whats involved or changed in the nitrous tune if I got a wet kit installed.
jdizzell
05-10-2005, 10:54 PM
Timing needs to be retarded.
Injuneer
05-11-2005, 02:21 PM
Don't change your PCM tune for nitrous. Adjust the A/F ratio on nitrous using the jet sizing in your wet kit. And use an external retard box to pull the required timing ONLY when you spray. Why screw up your NA performance by altering a good NA tune? You'll lose performance when you aren't spraying if you do that.
