How to turn off SES light?
RCF925
05-07-2005, 12:03 PM
I've been trying to pass smog and had to lean car out at idle by locking the blm's which is causing the SES light to come on and off randomly at idle. The smog guy won't start on the car unless theres no SES light. What's the easiest way to keep the light from coming on and then I will put things back to normal after passing smog?
StickMaster
05-07-2005, 12:46 PM
Car is a 94? he shouldnt even be looking at the SES light. There are constants in TC that give error codes that you can disable.
RCF925
05-07-2005, 02:19 PM
Ya I hear you, but this is CA and they are getting pretty up-tight. I have Tunercat so I'll disable the code, Thanks
RCF925
05-11-2005, 06:34 PM
The code I want to edit out to keep the SES light from coming on is 55 (lean condition) It's not in the constant table, so how would I keep it from turning on the SES light at idle.
97Z-M6
05-12-2005, 11:14 AM
send me a copy of your definition file to prove you have purchased it. and ill send you a link to the latest one (bj) and you can turn that off.
vincentbergeorn@yahoo.com
StickMaster
05-12-2005, 07:47 PM
:thumb:
