Whats The Best Oil Weight To Use???
Old May 6, 2005 | 06:42 PM
masiroc566's Avatar
Question Whats The Best Oil Weight To Use???
Hi on a new crated motor, what is the best weight of oil to use? I keep getting different results from everyone. I need a clear answer cause I dont want to harm the motor at all!! I live in west Tx so if you all have answers I would really apreciate it....Thx!!
Old May 6, 2005 | 06:46 PM
Black305RS's Avatar
Re: Whats The Best Oil Weight To Use???
depend where you live GM recommends 5W30 but 10W30 is good. never use a straight weight.
the ratings are read like this:
exmple: 5W30: this oil flows like a 5 weight oil at 0 degrees F and like a 30 weight oil at 210 degrees F.
when getting oil check the back of the bottle for the API donut. and make sure you get the proper rating. ex:SJ type. i forget what year range that oil is good for. you can check the owners manual or google it.
Old May 6, 2005 | 06:53 PM
masiroc566's Avatar
well the guys at pepboys told me to use 5w-20...which I am currently...is that good?
Old May 6, 2005 | 08:31 PM
LameRandomName's Avatar
If it was my engine, then once I'd gotten past the break-in period I would use 0w-30 Amsoil. (Or any other fully synthetic oil.)
You might also consider getting a remote filter setup, especially one of those bypass setups that have a regular filter AND a bypass filter. Amsoil sells those too.
Oh and, for the record; I'm not pimping Amsoil because I sell it. I don't.
I use it and I like it a lot, so I tend to tell people about it.
Old May 6, 2005 | 08:35 PM
Black305RS's Avatar
its not bad its just a thicker oil.
oh and from my experience people at auto parts stores generally dont know what they are talking about.
i once asked someone at one what a VSS was(before i knew) and i was told it was a vacuum starter solonoid. when it is a vehical speed sensor. and another time i asked where a radiator flush kit was and they handed me a a/c flush kit.
Old May 6, 2005 | 10:28 PM
masiroc566's Avatar
Okay...so what would you use to break in your motor and could the fact that the oil is so thick be the reason why I dont get a reading on the dipstick?...
Old May 6, 2005 | 11:03 PM
Black305RS's Avatar
Originally Posted by robvas
No. Break your engine in with some plain jane 10W30. Don't run anything like synthetic until you get a couple thousand miles on it.
i agree
and no the thicker oil has nothing to do with it not reading.
Old May 12, 2005 | 08:32 AM
brians96Z's Avatar
5w20 is not thicker oil that 5w30. 40 would be thicker than 30.
Old May 12, 2005 | 01:27 PM
87DJP2001's Avatar
Since you live in Texas where the climate is not to extreme just go with a good brand of 10W30. Also I suggest getting a 2qt A/C Delco oil filter (p/n PF-932)for that extra capacity for a total of Six quarts.
Old May 12, 2005 | 10:21 PM
Black305RS's Avatar
no you are wrong. lower numbers are thicker. higher are thinner.
Old May 13, 2005 | 12:27 PM
masiroc566's Avatar
well I settled with breaking it in with 5w-30.
Old May 14, 2005 | 10:15 PM
92RS305#2's Avatar
you can use a really crappy store brand oil for break in since its really heavy and will stick to parts during the critical break in, also use crappy store brand filter or fram filter since they flow bad but have good filtration. after 500 miles or so stick in 10w30 of a good brand like mobil one syn or non-syn depending on which way you want to go. and use a good filter too.
Old May 15, 2005 | 10:11 PM
89TramsAmGTA's Avatar
I would use the 5W-30. It's what the factory used to break in your engine when new. Allen
Old May 16, 2005 | 07:48 PM
92BLKL98's Avatar
Sorry Partner but the lower the number the thinner the oil. On a cold start the oil operates like a 0, 5, or 10 weight after the oil reaches operating temp. it acts like a 20, 30, 40, or 50 weight. You want a thin pourable oil that flows easy on start up hense the low weight number and thicker oil after warm up for its protective properties.
Oil has 5 duties inside an engine:
1 to cool
2 to clean
3 to seal
4 corrosion prevention
5 to lubricate
I would recommend 5W30 as does GM but 10W30 is OK. At the 500 mile mark I would do a first oil change to Amsoil 5W30 or 10W30. 0W30 is a good oil but I live in Georgia and I prefer the heavier oils.
Old May 16, 2005 | 09:52 PM
cc89formula's Avatar
look at the numbers on gear lube and compare it to motor oil...that will tell you he is right
