Shimming a resurfaced flywheel
blackz97
05-06-2005, 12:50 AM
Picked up my flywheel from the machine shop today. I asked the machinist about shimming the flywheel, he said it wasnt neccessary because they take less then .010 off the surface... Is this true or should i be looking for shims myself, and a new machinist?
Steve
MachinistOne
05-06-2005, 01:46 AM
Some flywheels have a minimum thickness spec, just like OHC cylinder heads. So yes, flywheels can be re-surfaced too much, if all they removed was .010" then you have plenty of material left. Flywheel shims are avalible in thicknesses of .025" and .050".
madwolf
05-06-2005, 02:06 AM
Sorry to use this thread, but do you know what is the stock thickness for an LT1 flywheel? I have an aluminum one that has been resurfaced and I might need to do it once again. I'd like to know if I can reuse it.
Thanks.
