blahster
05-03-2005, 03:29 AM
I will be getting some new 17x9.5" wheels. i can customize the backspacing.
My question is this...well actually i have 2 questions...
1. I want to have the new wheel stick out just like .5"-1" more than the stock wheel. What offset do i need to accomplish this?
2. Will 245/35/z17 tires be the right size for these wheels?
Thanks!
Dave '97 Z28 M6
05-03-2005, 12:20 PM
If the offset is correct, these 17x9.5's will stick out further, since they're 1.5" wider than what you've got now. You might get 3/4" on both sides of the wheel.
275/40 is the perfect size tire for 17x9.5's. If you wanted to stretch a 245 on those wheels, 45% would be a better aspect ratio than 35.
Injuneer
05-03-2005, 05:28 PM
The stock 16x8" wheel has a 55mm offset. That means the front edge of the stock wheel sticks out about 2.3" from the face of the hub (frontspace). That means for a 9.5" wheel, you are looking to move the outside edge of the wheel out 0.5" to 1.0". To do that, you would need an offset in this range:
2.3" + 0.5" = 2.8" frontspace = 60mm offset (too large a backspace, may not fit without rubbing on the steering knuckle)
2.3" + 1.0" = 3.3" frontspace = 48mm offset. This is OK, and will look exactly like the 17x9.5" OZ Monte Carlo's in this picture:
http://cjcfo.fbody.com/members/injuneerzz@aol.com/PhotosD/3_4View.jpg
You could even go a little lower on the offset... the TT II 17x9.5" wheels are 45mm offset, I believe, and this car has the TT II 17x9.5's in the front:
http://www.kellydrown.com/Showcase/120-2036_crw_std.jpg
On the tires, you really have to match the stock tire diameter. A 245/35-17 would be about a 23.8" diameter, which is almost 2" smaller than the stock 4th Gen tires (assuming your car came with 245/50-16's) and would drop the car 1" closer to the road, and would open up the already huge gap between the tire and the fender by a full 1". It would look terrible.
As noted above, most people will use a 275/40-17 or a 285/40-17 with a 9.5" wide wheel. But if you want the skinnier 245's, you need the 245/45-17, as noted in the post above.
blahster
05-03-2005, 06:26 PM
I'm going to be dropping the car an inch too so....
I want my wheels to look like the wheels in the first pic link you posted.
Thanks!
