Whats the bottle pressure like in the summer?
Black1995Z
05-03-2005, 02:28 AM
When its 110*+ in my car is the bottle going to be safe? Any saftey precautions I need to take?
lamb110
05-03-2005, 08:33 AM
you should probally get a blow down tube if you dont already have one, they are relativley cheap like 20-30 bucks depending on were you go
Nitro Dave
05-03-2005, 10:10 AM
The best thing is not to leave the bottle in the car.Take it out if your at work.The temps get so high in the car it could rupture the safety disk causing you to lose all you nitrous.
Dave
InsuranceGuy
05-03-2005, 11:59 AM
I've seen my bottle pressure above 1200 psi during the
summer here in Texas.
Emil
Black1995Z
05-03-2005, 02:53 PM
When spraying @ 1200 is that like spraying @ 950? or is it crappy like it is @ 600-?
InsuranceGuy
05-03-2005, 04:52 PM
The most psi I would spray at is 1100. My car seems to
run the best at around 1000psi so on a hot summer day
I have to purge the excess psi down.
Spraying at 1200 would hit "a lot" harder then 950. However,
you are risking running lean or your solenoid locking up.
Emil
