crAzy95z28
05-02-2005, 09:51 PM
http://www.ls1tech.com/forums/showthread.php?t=315843
having problems with bottle heater!crAzy95z28 05-02-2005, 09:51 PM http://www.ls1tech.com/forums/showthread.php?t=315843 markinkc69z 05-02-2005, 09:54 PM Jumper the pressure switch to test, or just ground that terminal. crAzy95z28 05-02-2005, 10:19 PM Jumper the pressure switch to test, or just ground that terminal. ? :confused: markinkc69z 05-02-2005, 10:30 PM the ground wire off the relay you have running to the pressure switch, bypass that directly to ground to see if the relay responds and the heater kicks on. Your pressure may be high enough already or the switch might be defective or need adjustment. crAzy95z28 05-02-2005, 10:40 PM there is no ground for the relay!~ markinkc69z 05-02-2005, 10:53 PM huh? there has to be. I looked at your post on the other forum. The pressure switch is the ground. You better read your directions again. Term 85 is usually the ground . crAzy95z28 05-02-2005, 10:57 PM i thought u mean the realy was ground...sorry bout that! what i was going to do is just take the 2 wires off the heater and make sure it actually heats up! crAzy95z28 05-02-2005, 11:46 PM fixed it...the damn adjuster screw was shut off!! markinkc69z 05-03-2005, 12:50 AM I'm glad you got it fixed. | ||
