slowpoke310
05-02-2005, 08:45 PM
what difference would it make with non adjustable as to adjustable trailing/control arms by RK sports??? ive installed a adj, torque arm bar, and have ordered a adj pan hard bar. would it be better to get the adjustable arms?
OBE1 95Z28
05-02-2005, 11:18 PM
No need for adjustable LCA's unless you plan to run a larger diameter tire.
slowpoke310
05-03-2005, 03:19 PM
i have 20" on now, but am going to take em off and put 19" on. i could afford either or but dont want to spend unnecesary money. plus the specs. on the adjustable ones looked weaker
OBE1 95Z28
05-03-2005, 03:40 PM
It's not the wheel diameter, it's the tire diameter. Tire diameter is usually 26". Some guys run 27" and 28" slicks to get a bigger tire patch for traction.
slowpoke310
05-03-2005, 05:27 PM
thanx 4 the feedbak, ima go with the non-adjustable arms, and adjustable panhard bar, as i do plan to lower the vehicle, once the wheels are changed.
