need opinion on new tires for 18's
kingman109
05-02-2005, 02:03 PM
well im running nitto 555's 275-40-18's currently and i burned through these tires in about 5k .. i had probably 4-5 track runs and a few big burnouts but mainly i found they sucked for traction and i could easily break em loose in 1st 2nd and even 3rd when they were semi new.
i cant justify spending 400-500 on 2 drag radials but i really need a good tire that sticks and gets decent treadwear. I also want to be able to make about 10 track passes this spring/summer.
So what do you guys reccomend... i really need to order them in next day or so as i need to drive home in 3 weeks and dont think the nittos will make it.
so please whats my best bet... ? ( this is just for my rear fronts have new tires)
Knowklew
05-02-2005, 02:09 PM
ummm...finding a tire with good treadwear is going to be detrimental to a tire that takes multiple trips to the dragstrip. You might want to consider getting some tires that wont see the dragstrip and buy some slicks for the track.
kingman109
05-02-2005, 02:16 PM
well with any luck ill end up picking up a set of slicks for my other rims... but untill i can afford it i need a daily driving tire that can hold its own on track...
thnx for opinion
AW/whiteZ-28
05-02-2005, 02:36 PM
You don't have your stock 16's around? You could throw some slicks on those or even some used DR's.
Sorry but there isn't really much you could go with in a 18" wheel.
EDIT: btw if you are burning out in street tires you really aren't helping that much just a quick spin to clean them off is all you need.
kingman109
05-02-2005, 02:49 PM
the stockers are back in CT ( which is what im planning on throwing some slicks on) and nope not burning out at track. NYIRP there is no way to avoid waterbox so i just give them a quick spin to get the water off.
