Does solenoid size affect jet sizing?
brain
04-30-2005, 12:14 PM
I am curious. Does the size of the solenoid make a difference in regard to the size of the hp shot with the same size jet? Example, - Super power shot with a 62 jet - is that equal HP as a Super Pro Shot with a 62 jet? Only other difference would be feed line to the solenoid. Solenoid to nozzle lines are the same, bottle pressure is the same. If it depends on how much nitrous is used, where is the general limit that they stop being equal?
NXRicky
05-02-2005, 12:19 PM
yes it will matter. On some applications not enough to worry about, on others send the system into a lean condition. The larger orifice solenoid will move more clean nitrous. What this means is less air bubbles in the nitrous stream. Cleaner nitrous more lbs. per hour for a given size of jet.
Ricky
