HELP!!! Im confused
KirbyZ28
04-29-2005, 02:55 PM
Ok I have a 2000 Z28 A4 and i just reciently put a NX Wet Kit on it everything worked good and so on well i was out racing a Corvette and after we got done racing i could smell OIL so i got off of the E-Way and pop my hood and i see that the Oil dipstick has came out and there is oil all over the engine (This only happens when I am Spraying) Now i know that the reason that it is doing this is that there is to much crank case pressure but why would it do that ... Rings? (I Hope Not!!)
LameRandomName
04-29-2005, 05:35 PM
Rings?
That's where MY two bits are.
InsuranceGuy
04-29-2005, 09:30 PM
Most likely cracked/broken ring lands.
With your engine idling, remove your oil fill cap and see
if you have the chug-of-death(blowby)coming out of the
valve cover. If so, its time for that rebuilt. Been there, done
that(twice).
Emil Dusek:93Z
profat54ht
04-30-2005, 08:54 AM
We just bought a 1968 Z/28 so we were told. Is there any web site we can check out vin # or cowl tag #'s?? Thanks profat54ht
Nitro Dave
05-01-2005, 11:23 PM
Take and do a compression test on the car.
This will tell you if there is ring problems.
Dave
