lowered 4th gens
Jakeav11
04-29-2005, 01:18 PM
how low is your ride...post pics
Compstall
04-29-2005, 03:56 PM
I can barely fit two fingers between the top of the tire and the fender.
n2oblkz
04-29-2005, 08:59 PM
Pics of mine are in my sig below. They are DMS springs and are lowered about 1 1/4 to 1 1/2.
JaysGone
04-29-2005, 10:17 PM
:cool: I cut my stock springs :eek: and have for years with no ill effects. 27 inches all around :D
musclecar
04-29-2005, 10:32 PM
I put Intrax springs in mine and it seems to be on the bump stops in the front...lol I rides ROUGH!! Looks cool tho!!
carlos64030
04-30-2005, 12:51 PM
There should be some pictures of the ride height of my car in my sig.
Bayer-Z28
04-30-2005, 09:24 PM
I heard Intrax were awesome springs.. How low did you go? I'm looking at a 1" drop w/ the 17" SS wheels, same ride height from a stock 16" Z28 wheel..
I've also heard that the BMR springs suck......??
musclecar
05-01-2005, 11:23 PM
It really didn't measure that much with a tape, but then again I don't know how much travel these cars have. I was told the springs were 2-2.5 but installed are more like 3. I have 18's on my car and wanted to close up the gap in the wheel well so I figured I would try them out!!
will62085
05-02-2005, 10:49 PM
with bigger wheels, you buy a thinner sidewall tire...and end up at the same ride height...my freind had the bmr springs, and i really liked the way those rode, i think it was a 1.5 inch drop
Compstall
05-03-2005, 01:10 AM
FYI, my 17" TT2's w/ 275/40/17 tires actually sit ~1" shorter in diameter than my factory wheels w/ 255/50/16's on them.
DrivinSidewayz
05-03-2005, 04:09 AM
your factory tires were supposed to be 245/50/16, not 255
when you calculate tire diameter between 275/40/17 and 245/50/16, it comes out to less than 1/10th of an inch. (in a perfect world)
Compstall
05-03-2005, 06:05 AM
I know what size they came with, I was just pointing that out.
FastrDamnit!
05-03-2005, 01:01 PM
riding on Sprint Springs 1.75" lower in front 1.5" lower in rear on SS (ZR1 wheel/tires). Looks great but very rough on bumps.
nfa
05-03-2005, 02:29 PM
1 coil cut from the front stock springs, 3/4 coil cut from the rear with isolator removed and heat hose on the top coil.
26" front height, 27.25 rear.
with st35mm swaybar, bilsteins, gw upper controls arms. it handles pretty good and the ride is far superior that stock.
-1.7 camber, 4.5 caster, 0 toe in.
