tryintogofast
04-28-2005, 12:29 PM
Heys Guys,
First a little info on the setup. It's a forged 383 with a s-trim. It will hopefully make around 550 rwhp with methanol involved. I'm also going to be running a 75 wet shot when better fuel/timing retard comes into factor. Now I already have a single 255 walbro and racetronix HW kit with 57 pound siemens. I want to make sure this thing doesn't go lean on me. I was thinking of running the dual walbros but have 3 questions about the setup.
First wiring side of it. Are you guys just splicing into the existing wiring and running both pumps off of that? If not how are you wiring the new pump in.
Secondly. Do HAVE to run the hobbs switch for this setup or can both pumps be running all of the time. I heard two heat up the fuel but I dunno if I believe it or not. If you don't need one I was just thinking of buying a y junction and using steel braided lines for the pressure to the y block.
Third. Do I need this system? I know I could just put on a BOP but I plan on upgrading the blower to a t-trim in the future and it would be nice just to take care of it once and for all.
Mikey
Thanks for the replies :D
Mikey
