jp2002ls1
04-27-2005, 12:30 PM
I am going to swap my 27 spline input shaft out for a 30 spline and I need: a 30 spline input shaft, aluminum drum assembly for a 30 spline, and pump stator or whole pump. Also a 10" 3000 to 3500 lockup stall converter if anyone has one.
If anyone has any of the following parts or a whole junk 700R4 with 30 spline input shaft please let me know.
Thanks,
John
Hot Rod Hawk
04-27-2005, 02:13 PM
Call Gordon Automotive and ask for Tim.
http://www.gordontransparts.com/
They can send that converter out for a stator change and you can pick a new stall at the same time you know. They carry Huges stators in stock here. Don't waste your time with a stock drum when you can get a "the beast" drum from Gordons for $40!
jp2002ls1
04-27-2005, 03:24 PM
Thanks, I know I can get my converter restalled but it is a 12" converter and I am looking to get a 10" converter, as small as I can get and still retain the lockup feature.
IrocSS85
04-27-2005, 06:49 PM
john, I can hook you up witht he parts. just stop by my work and pick up this trans I have torn apart. bring me back the stuff you dont use and I'll make you a real good deal on what you do use.
chris
jp2002ls1
04-27-2005, 06:57 PM
Hey Chris, sounds good, I can give you trade you good parts for the parts I need. I'll call you. Thanks.
I'm still looking for a torque converter. 30 spline, 3000-3500 stall range lockup 10"
jm8881
04-28-2005, 01:04 AM
I've got a 700r4 from a 1985 2wd suburban in my garage doing a whole lot of nothing. I don't know the spline count on it but can find out. Looking for $100 from it.
