Turbo W/AFR heads Plugs ?
JuicedSC
04-26-2005, 07:46 PM
I was trying to find out what would be the best plug to run with my setup ? It is an LT1 with turbo running 20+ psi. I was running a TR6 but was told to run a colder plug. Which set would be optimal for reliability with high RPM use ? Thanks
Mike
LT4ultraZ
04-27-2005, 02:25 PM
I run a autolight 103's on 15lb of boost and 100 shot of juce, i was running 104's with 15lb no problem. but sparkplugs are not the limiting factor for high RPM use as far as i know. The OPTI crap, ignition and valve train will be your limiting factor.
JuicedSC
04-27-2005, 08:46 PM
We have already spun the motor to 7200 rpm without a problem on the ignition, so i am not worried about that.
yellow Z28
04-27-2005, 09:46 PM
what size turbo are you running? and how much power are you looking to make??
engineermike
04-27-2005, 11:31 PM
Autolite 3922's are pretty cold and they have the gasket seat that the AFR's require.
JuicedSC
04-28-2005, 10:06 AM
It is a T-88, and hoping to make 900rwhp.
mehoffz24
04-29-2005, 08:07 PM
shouldnt use a 103 or 104 style plug with no gasket...
autolite 3922 3923 3924 14mm 3/4 reach 5/8 hex plug
coldest to hottest. probally wont want to go hotter then the 3923..
JuicedSC
04-29-2005, 08:56 PM
thanks for the info, I have decided to run the NGK R5762-8
mongse_1
05-02-2005, 02:20 PM
Ding ding ding! That's very important w/ AFRs. I used to have a x-reference sheet for AutoLite, Champion and NGK, but I think it's lost in the garage. :(
