Low Traction Light????
97_Z28
04-25-2005, 09:14 PM
I own a 97 Z M6 and when I am driving and apply the brakes, RIGHT before the car is completely stoped my "low trac" light comes on and the breaks surge slightly. I think it is a weak wheel speed sensor but I wandted to get someother opinions.
-Lee-
gsewell_uk
04-26-2005, 09:52 AM
You'll probably find this from a search of the message board. However, I solved this issue on my Z28 by reseating the connectors on the back of the front wheel hubs. Just remove the wheel for easier access and pull off/push on the connector two or three times to make sure that they are perfectly seated and clean.
Xride
04-26-2005, 08:54 PM
and make sure your not doing a hard stop on like gravel or something.
OBE1 95Z28
04-26-2005, 10:04 PM
I also had the same issue, the ABS sensor in the differential was cleaned (non traction control car).
97_Z28
04-26-2005, 10:17 PM
Hey guys, thanks for all the responces its been a great help.
-Lee-
CamaroSS30thAnn
04-26-2005, 10:20 PM
mine does it when applying teh breaks over a pothole or when i hit a pothole at a decent speed, i tend to swerve around em but once in a while they jump out at u
Grims
04-27-2005, 11:52 PM
i have the exact same problem, every now and then when i hit the brakes right before i stop it feels like i loose brake pressure and have to hit the brakes harder, then the low trac light comes on.
TobyZ28
04-28-2005, 02:17 PM
Ive had this same problem too, Its gone away for now, but seems to come back in the early morning winters when its cold and dewy outside.
Grims
05-19-2005, 12:02 PM
same here
WSUFlyer
05-19-2005, 03:28 PM
I've got a 95 Z28 that bleeps this light when I loose traction while accelorating....does that mean I have traction control?
ryan
Xride
05-19-2005, 06:42 PM
ryan
no
it means you have abs and it detected low traction :)
WSUFlyer
05-20-2005, 02:01 AM
Which cars had Traction Control....and how can u tell? I have assumed that ALL cars...no matter what make or model...with traction control has to have a button or switch to turn it off. True?
Ryan
Montezuma
05-20-2005, 02:08 AM
95 was the first year ASR came out. However, it only came out on cars made later in the year (mine dosn't have it). You'll know because there will be a switch.
Lower
05-20-2005, 02:57 AM
How are these cleaned? Do you just mean the plug in connection, or are you actually removing the sensor from the axle?
