wtb: opti
Old Apr 22, 2005 | 08:41 AM
weinerschizel's Avatar
wtb: opti
I want to convert my 94 nonvented opti to a vented opti setup. Does anybody have a 95+ vented opti and or timing cover? I will also need the necisary dowl pin to reach from the cam.
Otherwise I'm looking to find a dowl pin adapter to reach to the cam so I can use my non vented opti w/o the 94 style cam gear.
Thanks!!!
Old Apr 22, 2005 | 06:06 PM
hosspwr94's Avatar
Re: wtb: opti
I have a 95 opti with the vent tubes, all you would need to do is get a timing cover and you might be able to call Comp cams and see if they would send you a dowl pin to replace yours. do you have a stock cam or an aftermarket? If you already have an aftermarket sometimes they have the longer dowel already installed but it is pushed in to fit and you can pull it out and reset it to fit the longer reach. just a bit of info. I will sell you the opti and tubes shipped for 180.00
Thanks!!!
Old May 17, 2005 | 05:39 PM
junior7959's Avatar
Re: wtb: opti
I can get you the timing cover for a 95 for $75 shipped
Old May 17, 2005 | 10:46 PM
Re: wtb: opti
figured something else out. no longer in need of opti. thanks!
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
