SFCs and T-Tops Problems
Old Apr 21, 2005 | 08:06 PM
SFB767's Avatar
Question SFCs and T-Tops Problems
I'm getting my boxed BMRs welded in tomorrow.
I heard on another board that a guy who had the same ones installed had alignment problems with his t-tops afterwards and the windshield was slightly flared inwards.
Do you think that this was due to a poor installation or is this to be expected with the SFCs? I'm going to have my mech. use his drive-on lift for the installation, so hopefully everything will work.
Have any of you with boxed SFCs had this problem?
Old Apr 21, 2005 | 08:10 PM
NOMAD's Avatar
Re: SFCs and T-Tops Problems
If the chassis is twisted any when the car is being welded on, it will not untwist. If it's on a frame lift, it's going to be all f'ed up. Doing it on a drive on lift is the only proper way.
-Shannon
Old Apr 21, 2005 | 08:15 PM
stereomandan's Avatar
There should be no problems whatsoever. Actually, they will help to make sure that your car doesn't flex and have T-top or windshield problems. The key is to make sure that the car is level when the SFC's are welded up. The best lift is one that you can drive up on, that way you know it's level. If the car is on a four fork lift, and not supported evenly, you can imagine that when you weld the SFC's in, you are basically locking your chassis into a bent condition. We raised my car on the lift, and then lowered it onto solid concrete blocks that got the car up high enough to weld underneath. We still kept the lift forks under the car just in case, but they weren't touching the car. This may have been a little extreme, but I wanted to make sure the chassis wasn't tweaked when the SFC's were welded in. I have access to a lift 24/7, but I'm not sure your average muffler shop or garage will be willing to go through all this trouble.
:edit: Nomad, you beat me to the punch!
Dan
Old Apr 25, 2005 | 03:36 PM
gav'spurplez's Avatar
as others have said, proper installation is the key. the weight of the car needs to be on the wheels/chassis, so that the welds hold the car in that position.
i have the slp bolt-ons, and the weight of the car still needed to be like that for the install.
make sure you trust the shop/person doing it
and yes, sfc's are supposed to help the structural integrity of a t-top car
Alien
Jun 27, 2015 01:13 PM
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
siguy
Nov 27, 2014 10:07 AM
The Seer
Nov 20, 2014 06:32 AM
Krab
Aug 5, 2002 12:08 AM
