mehoffz24
04-20-2005, 12:39 AM
i have been trying to chase down this problem for a few weeks now and i just cant figure it out. i read the posts last week about another member with the problem, people suggested the intake gasket being bad, or a loose PCV. well now i have a brake booster check valve in line with the pcv, and i took off the intake to find out that the gasket is not damaged. PN 1236777
383 8.5:1 AFR 210s lt4 intake 224 236 114lsa d1sc.
right now im having a problem with only 4 PSI, imaging what it would be when i get it on the dyno. i have a breather on the PS valve cover and the PCV in the stock location. vacume line that originally went to the TB also has a breather in it. with 4 psi i have oil SHOOTING out of the dipstick tube.
only thing i havent done is a leak down test, BEFORE i put the charger on, i broke the engine in. it has about 650 miles now. before the blower install engine never leaked or used a bit of oil... please help
