Gmr Speed C5 Brake Brackets
GMR SPEED is now selling the UMI C5 brake brackets and the complete kits.This complete kit includes all hardware and components needed to complete the C5 brake conversion on any 93-02 F-Body.
Kit Includes:
- (1) Set - UMI Performance’s conversion brackets
- (1) Set - GM PBR Pressure cast front calipers
- (1) Set - Hawk HPS pads
- (2) Front Corvette C5 Raybestos rotors
- All necessary mounting hardware and installation instructions
Note: To install brackets both LT1 and LS1 spindles require modifications. This simple modification can be done while the spindle is on the car and requires a small amount of cutting. LS1 models require less cutting than LT1 models.
Benefits of Running the C5 Set Up
1. Larger Rotors: The larger rotor absorbs and radiates more heat, the C5 rotor is 1” larger then the LS1 rotor and 2” larger then the LT1 rotor
2. C5 Rotors are directional unlike the LT1 and LS1 set ups. C5 rotors feature fins designed to advance air flow allowing better cooling.
3. Many brake pad and rotor options are available for all types of driving
4. The C5 calipers are pressure cast not gravity cast; this helps increase caliper life
5. Unlike other brake set ups, C5 components can be purchased at any parts store. This eliminates down time when an item may fail or require quick replacement.
Requirements
This kit requires a minimum of a 17” wheel for clearance. All 1996 and newer 17” wheels will fit correctly with this kit. If you are running a different wheel set up please research fitment before purchasing.
From our research we have found the following wheels will NOT clear with the conversion kit, they may clear with the correct wheel spacers:
1. Enkei Win- 17” x 9.5”
2. 93-94 SLP Firehawk wheel- 17” x 9”
3. Borbet Type T- 17” x 9.5”
4. Forgeline RS Reverse Rim
Also if anybody is interested in a GP let me know.
Contact GMR SPEED for price info or pm me..Thanks Joel
1-330-273-4948 1-866-899-4948
Kit Includes:
Requirements
Re: Gmr Speed C5 Brake Brackets
PMs sent to all you guys....remeber let me know if you are all interested in a G/P....Also what kit do you guys want the most, is what the G/P will be on. Thanks Joel
