Anyone running a XE 224/236 cam in CA?
EDS Z28
04-14-2005, 11:08 PM
Hey guys,
I'm pulling out my gm hotcam due to a vented opti conversion.
I figured to upgrade the camshaft and other valvetrain parts while the motor is apart, again :p My motor is a blown 355.
I was looking at the CC XE blower grinds, 218/230 and the 224/236 duration at 114 lsa cams. Does anyone know if these are capable of passing smog. I did pass the last test easily with the hotcam. The 218 one looks like it has no overlap, while the 224 has 2 degrees of overlap, which isn't all that bad.
Does anyone know how much overlap the hotcam has? I don't even know.
I liked the sound of the 224/230 from a video on LT1 tech, it sounded awesome.
Looking to add some beehive springs along with the cam.
OBE1 95Z28
04-15-2005, 12:16 PM
I'm running the 218/230/114LS cam in my blown 350 95 Z28 and my friend runs the 224/236/114LS cam in his blown 383 95 Z28 with AFR heads. Both cars here in San Diego passed smog.
EDS Z28
04-15-2005, 12:27 PM
OBE1,
Hey man thanks for that info. That's good news. How is the idle on your cam, is it lopey and how much vacuum? With the hotcam I had around 15" manifold vacuum at 900 rpm.
I'm leaning towards going with the bigger cam since my car is not a daily driver. :cool:
D James
04-15-2005, 10:33 PM
well my 224/236 doesn't lope very hard, actually its very slight, unless you open a cutut, then it gets ok. Drivability is great, I never tuned mine so there was some slight cam surge at 5-10 mph, but thats it, all other manners were great, I don't know how much vacuum it had, but I couldn't tell a difference in braking and it idled fine
EDS Z28
04-15-2005, 10:44 PM
Thanks for the info James. I had a little cam surge too with the hotcam. It's no big deal to me.
Looks like I'm goin the 224/236 route. Now, I need the other valvetrain parts to go with it. According to comp cams catalog, the springs to get are the 986's. I was going to go with the beehives, but have read some negative comments about them from Crane.
97WS6SCharged
04-15-2005, 10:53 PM
I'm running Combination's EX612 springs with mine. :)
OBE1 95Z28
04-15-2005, 10:56 PM
I pull 17" of vacuum at 900 rpm with the 218/230. I had pretty bad cam surge until I hooked up with a great tuner - Jeff Creech. Only a slight lope with this cam.
EDS Z28
04-15-2005, 11:20 PM
Wow, 17" is pretty damn impressive. I wonder what Jeff did to smooth it out? I know it's all a secret though :D
I know adding fuel to the motor at lower rpm's helps the idle a lot. The problem is this may burn out your cats, which are designed to run around stochiometric 14.7:1 most of the time.
How can I get ahold of Jeff?
OBE1 95Z28
04-17-2005, 08:28 PM
Jeff owns Carolina Auto Masters, a tuning shop in North Carolina. A local guy, SS MPSTR, has organized 2 group dyno sessions which makes it worth Jeff time to fly out to Southern California for a 3 - 4 day tuning session. Plans are to have Jeff back out by June. See the thread below for details of the last session:
http://web.camaross.com/forum
s/showthread.php?t=351603&highlight=Jeff+Creech
Private post SS MPSTR to get on the list for the next tuning session.
limige
04-19-2005, 08:45 PM
Hey, check your pm.
mike
c0rey
04-23-2005, 09:50 AM
I just ordered the XE 224/236. I ordered the whole valvetrain. I cant wait to get it in and see how it sounds. Does it sound simalar to a hotcam?
sherwinZ28
04-25-2005, 03:33 PM
I passed my 230/236 112 LSA heads cam 96 OB2 Z-28 at a test only center here in cali. The car is stock bottom end untuned...waiting for tunercat. No tricks were used as far as i know.
