gauging interest in my racecar?
97SSmokem
04-12-2005, 05:20 PM
I have a 1994 Camaro Z28.
Forged LT1 383
New Opti
TH400 built to handle 1100 Horse power with trans brake full manual valve body.
steel drive shaft with dana yokes
Moser 12 bolt 30 spline axles with 4:10s also have a spool to put in.
Cold fusion nitrous kit with bottle warmer, purge kit, preasure gauge
6 point cage welded in
5 point harness for driver
B&M quick pro lock out shifter
bmr subframes
bmr adjustable torque arm
bmr k member
bmr lower a arms
bmr lower control arms
Weld draglites front and rear
28x11.5 rear hoosier quick time pros almost brand new, 5 runs on them.
165x6 fronts ( i think)
Also have LT1 edit and will throw a laptop in with purchase.
Car is very consistant. last Wednesday 11.20 11.24 11.20
Car will come with a 22' car hauler for the right price..
This is a racecar.. No A/C, no radio, no heater.
I drive it on the streets every once in awhile. Not often though. Car has been programmed so that I can run leaded race gas in it. So at $5.50 a gallon I don't go far in it.
I have pictures for those interested and videos if you want to see it run.
I was going to ask $15,500 for everything trailer and all.
