Idle adjustment??
Old Apr 12, 2005 | 02:30 PM
Sweetred95ta's Avatar
Idle adjustment??
I am so new at tuning. I don't know where to start. Just wanted to know simply how to raise and lower the idle using tunercat.
Thanks,
Benji
Old Apr 12, 2005 | 03:19 PM
turbo_Z's Avatar
Re: Idle adjustment??
IAC Target RPM vs Coolant temp. Make sure you change both the in drive and neutral/park.
Old Apr 12, 2005 | 11:04 PM
Ryan94ZA4's Avatar
Yes, very easy. Also, don't forget to set your IAC counts so the idle doesn't drop or stay high and slowly come down.
RYan
Old Apr 12, 2005 | 11:36 PM
I found the target RPM, but what are the IAC counts? I found it in Throttle Follower IAC Offset Vs. MPH, but what do I change them to? It is at 6 for 0 mph. What is this? I appreciate the help guys.
Thanks,
Benji
Old May 11, 2005 | 07:19 AM
Just needed to know about the counts. See previous post.
Thanks,
Benji
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
edman
Jan 25, 2015 02:41 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
