What happens when you put a STS kit on H/C
Old Apr 9, 2005 | 11:25 AM
TireMarx723's Avatar
Say i wanted to get Lloyd Elliot Heads cam, would I still see another 100rwhp kick in the pants from a STS? Has any1 dynoed a Cam/STS setup on a LT1? Yes i did search the topic
Old Apr 9, 2005 | 12:40 PM
ajschult's Avatar
Re: What happens when you put a STS kit on H/C
I would imagine it would make some great power, even better if you lowered your compression.
Old Apr 9, 2005 | 01:41 PM
F8L Z71's Avatar
There are too many variables in your setup to know how well the turbo will work on your car.
If you are higher compresison than stock you won't be able to run much boost. If your cam has tons of overlap you'll bleed off lots of boost as well. So HP gains will be there but it's not the optimum setup..
Now if your compression is stock and your cam has minimal overlap then your gains from the turbo will be better.
Either way find a great tuner and life will be much easier.
D1SC383LT4
Jan 1, 2016 01:56 PM
Jan 23, 2015 01:13 PM
alphaauto
Jan 22, 2015 08:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
