how often do you guys check your plugs?
Old Apr 6, 2005 | 09:53 PM
Makaveli's Avatar
i know that its advised to check your plugs for signs of detination when you use nitrous, but do you guys do it every time you spray? or do you do it until you find a settup that works fine (timing, etc) and stick with it, only checking every once in a while? i have stock manifolds right now, and im sort of stuck with them until i can get by emissions in august or so, so plug checking isnt exactly painless. just wondering, thanks for the input
Old Apr 7, 2005 | 04:18 PM
84 monte SS's Avatar
Re: how often do you guys check your plugs?
I change my oil and plugs every 3-4 bottles which is every other saturday. I mean thats what i would do because i dont have nitrous or anything..... hehehe
Old Apr 7, 2005 | 05:08 PM
Makaveli's Avatar
how long have your plug changes turned into? i hear it gets a lot easier with practice haha
Old Apr 8, 2005 | 12:44 AM
13sectransam's Avatar
Mine took 5 hours
Old Apr 8, 2005 | 02:56 PM
izzyz28's Avatar
I pulled a couple of plugs after spraying it a few times in a row. They both looked perfect so I put them back in and left 'em. My setup runs a little rich with plenty of timing pulled out(5 degrees on a 125 shot), so I'm not worried about running on the edge or anything. I'd say spray it, pull a couple plugs, throw them back in if they look good and spray the crank out of it.
grabbem88
Feb 13, 2015 03:09 PM
cmdeshon
Dec 27, 2014 10:06 AM
danielbmx
Aug 27, 2002 11:11 PM
Red97LT1
Aug 7, 2002 05:45 PM
