deadmeat2004
04-04-2005, 07:23 PM
i have a 95 v6, with the old crank windows..kinda wanting to put a set of electric in... is the wires there to do it in the door?? I know it has power locks with my alarm, but??
wanting electric windows...deadmeat2004 04-04-2005, 07:23 PM i have a 95 v6, with the old crank windows..kinda wanting to put a set of electric in... is the wires there to do it in the door?? I know it has power locks with my alarm, but?? Sergio 04-07-2005, 10:22 AM Nah, it doesn't have the wires, nor switches. You might wanna look at the 'Electric Life' power window kit from Jegs which is especially made for our cars. They can also supply switches but you can get those from any salvage yard also. Retrofitting them using the factory assemblies is also possible and involves drilling out some rivets and bolting them in. Don't get the kits that put a motor around the old mechanism that's like a chain to drive the old shaft. Just get the original setup using a motor coupled to the scissor like mechanism or the aftermarket as described above. 99blackSS 04-08-2005, 05:20 AM Manual windows dont use the same regulator (scissor mechanism)? If they did that would cut out about half the work. | ||
