Did Interior with LED's...Uh Can I go Brighter?
Need4Camaro
04-04-2005, 12:54 AM
They're red but the A/C and Shifter plate is PRETTY dim you can BARELY tell they're lit even at night... Any bright RED LED's out there that are small like the 74 Bulb size?
97FormulaWS-6
04-04-2005, 07:34 AM
Just look for any high-brightness T-5 LEDs, they are directional, so overall they maybe still dim.
Need4Camaro
04-04-2005, 01:38 PM
What happens if I use a wide angle LED?
97FormulaWS-6
04-04-2005, 07:17 PM
You just loose some intensity, the same amount of light, you just spread it out more.
Need4Camaro
04-04-2005, 07:24 PM
I see so would those be better?
97FormulaWS-6
04-04-2005, 07:48 PM
Honest, answer, I don't know; something I'd say you'll have to experiment with.
WS6Extreme
04-04-2005, 08:43 PM
I have some Red 20,000 mcd LED's with a 4 degree viewing angle can can be modified to provde you with the light you should need. I was using them in my Cargo Light and Map Ligth LED conversions. If you want bright these can cause eye damage if you look directly into them..
I have red 30,000 mcd 9 degree viewing angle LED's on the way. :D
Need4Camaro
04-04-2005, 08:46 PM
Whoa where'd you get those?
97FormulaWS-6
04-05-2005, 07:26 AM
The 4* and 9* is great for spot lighting, but for area lighting it sux. I've got some LEDs here at work that will blow those away, but they are SMT (surface mount) and actually require a heatsink to function properly; but when you are talking 150 cd with a 60* beam spread... that's a lot of light.
WS6Extreme
04-05-2005, 09:43 AM
Care to share who makes them and the part numbers?
The LED's I mentioned would work fine if you modified the housing a little to better light dispersion. Yea you give up some of the mcd, BUT it will illuminate a larger area without a heatsink. :)
meissenation
04-05-2005, 05:36 PM
Oznium.com has red leds with an 8000 30-some degree viewing angle, at 34 cents each, it's a pretty decent buy...
97FormulaWS-6
04-05-2005, 09:59 PM
www.lumileds.com for the product, www.futureelectronics.com for the sole distributor.
Need4Camaro
04-09-2005, 11:25 AM
Do those come with resistors so I can wire it directly to my car? Will I have to drill a larger hole for the shifter plate?
