phinger23 04-03-2005, 01:34 AM Possible??
Discuss...im interested. i think my motor has some serious issues...so yea im interested in maybe a northstar motor if possible
95GRNZ 04-03-2005, 01:52 AM With enough money, skills and time many things are possible with cars.
TS
phinger23 04-03-2005, 03:04 AM With enough money, skills and time many things are possible with cars.
TS
well, yea true, but the average joe, with enough money to fix the car right, and not pour money into this LT1 motor i have now if its not worth it kinda person
Z28SilverBullet 04-03-2005, 05:35 AM Probably better off fixing the LT1. Engines that aren't supposed to be in certain cars usually involve more than just swapping in the motor.
BLACKBIRD8200 04-03-2005, 10:43 AM if you thought your LT1 was bad. wait to till you get your NS they're junk i have heard way to many bad things about them! and good luck changing your starter on the NS.
SFB767 04-03-2005, 12:10 PM Isn't the Northstar DOHC V8 physically larger than an LT1?
I would think so due to having two cams in each head like the Ford DOHC V8, which is larger than a SBC.
If this is true, you might have less room to work in your engine bay if you go through with the transplant.
anasazi 04-03-2005, 12:25 PM Isn't the Northstar DOHC V8 physically larger than an LT1?
northstar is considerably larger if i recall correctly.
much much cheaper and get more power with an LS1 swap :)
or just fix your LT1
myslowcamaro 04-03-2005, 12:35 PM Isn't the Northstar DOHC V8 physically larger than an LT1?
if they can stuff a 502ci in them im sure they can fit a northstar
jakef2003 04-03-2005, 01:11 PM There was a member here a few years back. Turbowash IIRC. He had a black LT1 car with a Turbo Northstar on Fikse's.
Pandamonkey 04-03-2005, 03:13 PM There was a member here a few years back. Turbowash IIRC. He had a black LT1 car with a Turbo Northstar on Fikse's.
I remember that......I was just about to mention it myself.
I guess it takes someone who's been here a while, like us.;)
Mike94ZLT1 04-03-2005, 03:37 PM www.hpsalvage.com
And there it is!
MotorCityNova572 04-03-2005, 03:47 PM if im not worng ant the starter in side the motor block..??? Thats just what i was told by a co-worker
95GRNZ 04-03-2005, 10:39 PM well, yea true, but the average joe, with enough money to fix the car right, and not pour money into this LT1 motor i have now if its not worth it kinda person
Fix your current engine or replace it with another LTI (or LS1). Much easier and cost effective and achievable on a budget..
BLACKBIRD8200 04-04-2005, 06:05 PM if im not worng ant the starter in side the motor block..??? Thats just what i was told by a co-worker
you are correct. and the block is two peices put together. junk
jakef2003 04-05-2005, 06:25 PM I remember that......I was just about to mention it myself.
Wow, I feel old now. 5 years :eek:
Dave89IROC 04-05-2005, 06:39 PM if im not worng ant the starter in side the motor block..??? Thats just what i was told by a co-worker
its in the valley under the intake
