honda_hater
04-03-2005, 12:29 AM
i was wondering if anyone could tell me if there is a big difference between the LT1 engine and the LS1 engines? i was wondering if anyone knew the hp of them for a stock engine aswell.
LT1 vs. LS1honda_hater 04-03-2005, 12:29 AM i was wondering if anyone could tell me if there is a big difference between the LT1 engine and the LS1 engines? i was wondering if anyone knew the hp of them for a stock engine aswell. NewbieWar 04-03-2005, 01:52 AM i believe LT1 275 (93-95) or 285 (96-97) HP LT1 325 TQ LT1 sounds better and feels more ballsy but really isnt... the ls1 is realitivly quiet and doesnt sound as muscly LS1 325 HP LS1 350 ??? TQ brink 04-04-2005, 01:05 AM ya until u put a slp loudmouth on a ls1 :bow: 2001 B4C 04-04-2005, 02:30 PM LT1 = 1955 updated technology, opti spark problems, water pump problems, insufficient head flowing problems, cast iron block LS1 = 1997 high technology, amazing flowing stock heads, individual coil packs, all aluminum motor, 6 bolt mains, stock motor will basically handle whatever you throw at it as long as you replace the valve springs and oil pump 94m5 04-04-2005, 04:07 PM LT1 = 1955 updated technology, opti spark problems, water pump problems, insufficient head flowing problems, cast iron block LS1 = 1997 high technology, amazing flowing stock heads, individual coil packs, all aluminum motor, 6 bolt mains, stock motor will basically handle whatever you throw at it as long as you replace the valve springs and oil pump Sounds like your a little partial to the LS1. I prefer the lt1/4 over the GenIII engines, BUT, that's only an opinion. I prefer the low end torque that the lt1 has, opposed to the highway pull the ls1 has. I have worked on ALOT of LT1's and have no problem fixing what ever goes wrong with them. They are cheaper, and ALOT easier to make BIG power with. Also.....this type of question has been beat to death, do a search for it, and youll have all the answers you'll ever need. Mike codyss 04-04-2005, 04:31 PM LT1 275HP 93-95 / 285HP 96-97 325FtLbs LS1 340-350HP 345-350FtLbs ImportKILLER 04-04-2005, 05:16 PM LS1 > LT1 LS1 = better top-end power LT1 = better low-end power | ||
