GreenCamaro619
04-02-2005, 03:52 AM
I have a 2000 3.8L camaro. Well geezo peetzo!!! I noticed I had a problem with my car one day when I was entering the freeway. I stepped on the pedal to catch up to freeway speed. Then it seemed like my car was bogging. Like when you press the pedal all the way down, it seems like my car is just like, "Don't even try." I can compare it to when person is walking their dog...The owner walks faster but the dog pulls back because it doesn't want to go faster. I hope this paints the picture for anyone who comes across this. This is like the first problem I ever had with my car!!! HELP!!! SOMEONE!!!
I FORGOT TO ADD THAT MY CAR WON'T REV PAST 3000 RPM...maybe my mass air flow sensor?
ianwells100
04-02-2005, 04:18 AM
most likely, you need a tune up, simple as that, our cars are notorious for this kind of stuff
i personally think its the plugs/wires.... me, i'm doing a tune up over a month (due to lack of time), so, if u wanna start cheap, clean ur air filter, replace the pcv valve, change the fuel filter, then do plugs and wires (which are most likely the cause of ur 'bogging'/any misfires you may be getting)
it's not an expensive fix, for all the above <<$100
Shirl
04-02-2005, 11:10 AM
It sounds like the catalytic converter went. It's clogged in there. Have a backpressure test done to be certain. You can look into a high flow cat as a replacement. If it were the plugs, you'd most likely hear it misfire and sputter at idle.
camarobiatch
04-04-2005, 01:43 PM
I have a 2002 3800 in mine. When I gun the gas off the line, it bogs like that , but only when you ASR is engaged. It doesnt do it if the ASR is disengaged.
deadmeat2004
04-04-2005, 07:20 PM
try tune up...fuel and air filters... wires and plugs..ect. check cat also. prob just a tuneup
00blky87fb
04-04-2005, 09:52 PM
if u dont mind me askin, wut the hell is the asr? do y87 firebirds have it?
camarobiatch
04-05-2005, 02:10 PM
ASR is Acceleration Slip Regulation. It is a traction control system that limits wheel spin on slippery road or (when you take off buy gunning the gas ) When the ASR is working<while you are slipping> it reduces engine power so you don't spin out . It also operates on dry roads like if there is dirt on the road or your tires are bald.
I don't know if you're FB has it or not . I only know that my camaro does . ;)
It can also engage if you accelrate hard on a turn or your tranny downshifts or upshifts "all of a sudden" like whe you are entering a freeway !!
Hope this helps
ImportKILLER
04-05-2005, 04:14 PM
I've got money that it is a plug/wire going out. Sounds like a misfire.
Might as well do both plugs and wires since you have a nice weekend tuneup job ahead of you.
deadmeat2004
04-05-2005, 04:31 PM
:thumb: right...i think thats what it is.
GreenCamaro619
04-06-2005, 03:53 AM
I posted up this problem a few days ago. The problem was my cat converter. The mechanic said it was practically falling apart inside. So crap was all clogged up. Got it replaced cuz there is some kind of warranty from the dealership for that. Got it replaced the other day. My car is back to normal...YEAH BABY!!! Thanks to those who replied to my post with ur suggestions.
wolfdogjr
04-12-2005, 12:55 AM
o.k guys & girls, I seem to have a similar problem with my 96 v6 RS...only my throttle go's up & down when it reaches 3500rpm,it runs good as long as i keep it under 3500 but i did install a air/fuel gauge and according to the gauge and my meter the voltage spases out!!after the o2 sensor warms up.what do you guys recommend?I also hada new high flow cat put in & still same problem,please help...
