Ok guys..what did i break this time?
LoudmouthSS
03-28-2005, 03:11 PM
This is beginning to suck lol. I find out something new everyday about this damn car that the previous owner decided to do. Well today as i torn into all the wiring and tubing (removing so i can pull the engine), I found that the egr tubes were cut anyway, so it wasnt even hooked up, i found a cut wire that was just hanging out at the bottom of the engine bay and last but not least i went to pull the tubes off this little saucer shaped plastic thing next to the egr..and as i pulled the tubes, they tore off the plastic "tabs' that stick out for the tubes to connect too. :mad: ...Anyway heres a pic of it and where it went in the engine bay. I thought it was part of the egr, but it had coolant in it?...so what is it? thanks guys
http://memimage.cardomain.net/member_images/7/web/751000-751999/751861_33_full.jpg
http://memimage.cardomain.net/member_images/7/web/751000-751999/751861_34_full.jpg
http://memimage.cardomain.net/member_images/7/web/751000-751999/751861_35_full.jpg
IROC-T
03-28-2005, 03:18 PM
That is your heater control valve,they'er cheap under $10 bucks. They break easy because they aren't made very well and they get alot of heat. :)
Never twist the hoses' on plastic parts alway cut the hose some of the parts that break are hard to get to,and hose is cheap.
LoudmouthSS
03-28-2005, 03:56 PM
thanks alot man, i appreciate the quick response. Ill deff take that advice next time i go to tear a hose off..thanks again
slimdawson
03-29-2005, 03:14 AM
You should just get rid of the valve and be done with it.
respectirocz
03-29-2005, 09:34 AM
the heater control valve is cheap and easy and if you need to run air conditioning, u need that valve, because without it, collant constantly flows through your heater core and makes alot of heat in the cabin
LoudmouthSS
03-29-2005, 10:45 AM
yea if fl..so ill be keepin the ac. Ill just go pick one up later on. Where can i get 1? just go to an autozone? or do i have to order it?
respectirocz
03-29-2005, 11:32 PM
yea autozone should have it, if they have to order it, it will take like 7-8 days
LoudmouthSS
03-30-2005, 12:28 PM
iight thanks guys
