How much HP? SC ?
Old Mar 27, 2005 | 12:47 PM
95lt1aholik's Avatar
How much HP? SC ?
How much Hp would you get out of a stock 2001 ss with a slp loudmouth with a vortech sc the one with the power cooler. Thanks.
Old Mar 27, 2005 | 01:21 PM
myslowcamaro's Avatar
Re: How much HP? SC ?
how much boost? go to www.superchargersonline.com and midway down on the right is a hp calculator. just plug in your existing hp and boost you want and it does the rest. a good estimate anyway.
Old Mar 28, 2005 | 08:06 AM
Bayer-Z28's Avatar
20% over stock. It's definetly worth it, IMO. I am definetly looking into one when I get the $ to throw around. Stay at 6psi for now. You can allways add a smaller pulley for more boost. I believe 360 rwhp, not sure though.
Old Mar 28, 2005 | 07:00 PM
Antz97ZNJ's Avatar
a blower even at 6 psi will give you way more then 360 rwhp
Old Mar 28, 2005 | 10:20 PM
BirchMan98z's Avatar
Gains are usually around 120-150rwhp, but can go higher/lower depending on bolt-ons and where you want to go with the boost-- and how long you'd like your engine to last.
Old Mar 28, 2005 | 10:25 PM
Drew778/94Z's Avatar
I'd say 415-425 rwhp with a M6 and a little lower with A4.
Old Mar 29, 2005 | 07:11 AM
Bayer-Z28's Avatar
I mean with a stock motor. Yeah, bolt-ons and headers will help it out quite a bit. Like i said, I'm not sure.
Old Mar 29, 2005 | 03:29 PM
The stock '01-'02 manifolds flow good, plus stock with a catback should be around 310-315 rwhp and 320-330 rwtq.
If he spends $6K for the kit and only 360 rwhp, I'd drive off a cliff
