aboadnan
03-26-2005, 10:37 PM
I am building a stroker F/I 8.1L , how much is the block good for?
Thanks.
Thanks.
8.1 L Qaboadnan 03-26-2005, 10:37 PM I am building a stroker F/I 8.1L , how much is the block good for? Thanks. Injuneer 03-27-2005, 12:34 AM What big block are you starting with... Gen 1 or Gen 3? Factory or aftermarket? aboadnan 03-27-2005, 01:54 AM Thanks for the fast reply, It is Factory GEN 3 (VORTEC 8100) AdioSS 03-27-2005, 04:32 AM I'd say that block is good for well over 1000hp :D aboadnan 03-27-2005, 06:10 AM I'd say that block is good for well over 1000hp :D Thanks for the reply you made feel good, has anybody done it? rskrause 03-27-2005, 06:10 AM Unlike the OEM SBC, that stock BB cylinder case is a stout piece, even with the factory 4-bolt iron caps. But as with any block, there is no HP limit per se. If you are building a huge hp blower motor (is that what you mean by F/I?) the issues are cylinder wall thickness and head gasket retention. Get any additional displacement from stroking the motor, keep the boring bar on the bench, as much as possible. Use high quality head studs and avoid milling the heads to the extent possible. Milling will decrease the thickness of the head deck and decrease resistance to distortion. One advantage of aftermarket blocks are extra head stud bosses in the lifter valley, which provide extra clamping for the heads. For a street/strip application, try some of the MLS gaskets. For a race application, use copper. MLS = Multi Layer Steel (Cometic, Mr. Gasket, others) As with a SBC, block fill will stabilize the block. A partial fill is compatible with street use. Unless you have an incredibly stout chassis and drivetrain and a huge blower, a factory 502 will probably take all you throw at it with some basic attention to proper preparation and assembly. Rich AdioSS 03-27-2005, 06:52 AM Thanks for the reply you made feel good, has anybody done it? that motor is fairly new and only available in trucks and for boats and industrial use. You might want to get in touch with these folks http://www.raylarengine.com/ or somebody that builds engines for offshore powerboats. :D We've seen a few examples of the small block LT1 holding in excess of 1000hp and the big blocks are just plain bigger and stronger. aboadnan 03-27-2005, 08:39 AM rskrause The block is 30 over and the stroke is 4.5 and for now i am planning to use Whipple supercharger w/intercooler 10 psi ,low CR pistons, supercharger cam, aluminum cylinder heads, "CoolGap" intake manifold from Rayler and the rest of the forged parts. -------------------------------------------------- AdioSS Thats where i am going to get my parts. Her in Saudi Arabia they bore the LT1 125 over and they use 400 SB pistons along with 100 + shot of the mass distruction weapon, atleast three or four engines has been done like this and non of them failed, forgot to add that they port the heads,hot cam kit, and reved over 6K RPM. Injuneer 03-27-2005, 11:31 PM Unlike the OEM SBC, that stock BB cylinder case is a stout piece, even with the factory 4-bolt iron caps...... Rich Did you pick up on Gen 3? I would assume with the relationship to the LS1 smallblock, that the big block version would have similar 6-bolt mains. Is that not the case? Boost It! 03-27-2005, 11:38 PM damn, stroking a 8.1L. I hope that thing has some awesome heads. Injuneer 03-29-2005, 12:32 AM Here in Saudi Arabia they bore the LT1 125 over and they use 400 SB pistons along with 100 + shot of the mass distruction weapon, atleast three or four engines has been done like this and non of them failed, forgot to add that they port the heads,hot cam kit, and reved over 6K RPM. .125 over on an LT1 block? Without a sleeve? You can't be serious. aboadnan 03-29-2005, 01:22 AM Injuneer here are some pic http://groups.msn.com/aboadnan/mis.msnw?action=ShowPhoto&PhotoID=22 it looks like the old big block ===================================== http://groups.msn.com/aboadnan/mis.msnw?action=ShowPhoto&PhotoID=18 Here it is like the LS1 but bigger ======================================== Here with the coils http://groups.msn.com/aboadnan/mis.msnw?action=ShowPhoto&PhotoID=24 ============================================== Here is the EX side, doesn't look like the old big block http://groups.msn.com/aboadnan/mis.msnw?action=ShowPhoto&PhotoID=21 ================================= this is the whole album http://groups.msn.com/aboadnan/mis.msnw ====================== Lt1 and 125 over is true because there so many available and and cheap and we have some crazy pepole to willing to try and they did, i am like you i asked my freind more than once and saw the engine ( from outside). ======================================= ======================================= ======================================= Boost It! i am going to use these heads http://www.raylarengine.com/head.htm =========================================== Will try to keep you posted as i go along, i have my AWD dynojet and hopefully if i get good HP # (god willing) i will tell you about it. Thanks everbody Flip94ta 03-29-2005, 11:46 AM rskrause The block is 30 over and the stroke is 4.5 and for now i am planning to use Whipple supercharger w/intercooler 10 psi ,low CR pistons, supercharger cam, aluminum cylinder heads, "CoolGap" intake manifold from Rayler and the rest of the forged parts. -------------------------------------------------- AdioSS Thats where i am going to get my parts. Her in Saudi Arabia they bore the LT1 125 over and they use 400 SB pistons along with 100 + shot of the mass distruction weapon, atleast three or four engines has been done like this and non of them failed, forgot to add that they port the heads,hot cam kit, and reved over 6K RPM. Which whipple are you gonna use? aboadnan 03-29-2005, 01:17 PM Which whipple are you gonna use? look under superchargers and nitrous http://www.tbyrnemotorsports.com/81truckcatalog.html Injuneer 03-29-2005, 01:19 PM Injuneer here are some pic http://groups.msn.com/aboadnan/mis.msnw?action=ShowPhoto&PhotoID=22 it looks like the old big block Thanks for the Gen 3 BB 101 lesson, but we're already familiar with that engine here. Lt1 and 125 over is true because there so many available and and cheap and we have some crazy pepole to willing to try and they did, i am like you i asked my freind more than once and saw the engine ( from outside). I'd have to see it to believe it (from the "inside", not the outside). The fact that people are "crazy" doesn't allow the engine to magically have thicker cylinder walls, to allow that much overbore. There was a thread here in the past two months where someone INSISTED he could bore .125 over, we all told him it couldn't be done, and when his shop bored it, they ruined the block. I've also got sonic measurements of my LT1 block somewhere, and there is no way the block could have been taken to 4.125 and stood up to "100 + shot of the mass distruction weapon" As far as the Whipple, Whipple sells both emissions compliant and non-compliant versions of the S/C for the 8.1L Gen 3 - both intercooled and non-intercooled versions. They have the HP and torque curves for the emissions-legal setup on their website. http://www.whipplesuperchargers.com/products.asp The kit on a stock 8.1 makes over 800 lb-ft of torque at 3,000rpm. airflowdevelop 03-30-2005, 02:05 PM We have seen many 2 bolt lt-1's with over .270 on the thrust side of the bore...plenty of thickness for .125 overbore. We have a couple emeritz (sp?) customers with the big bore...no issues as of now. sister cylinder dissipation is a problem under .150" but the reverse cooiling seems to solve the problem. Also, on the 8.1.... you should have no problems with the horsepower level you are shooting for. Dennis aboadnan 03-31-2005, 12:50 AM We have seen many 2 bolt lt-1's with over .270 on the thrust side of the bore...plenty of thickness for .125 overbore. We have a couple emeritz (sp?) customers with the big bore...no issues as of now. sister cylinder dissipation is a problem under .150" but the reverse cooiling seems to solve the problem. Also, on the 8.1.... you should have no problems with the horsepower level you are shooting for. Dennis Thanks for the info. | ||
