LoudmouthSS
03-25-2005, 12:29 PM
How can i do it?, What problems will i run into?
Deleting EGRLoudmouthSS 03-25-2005, 12:29 PM How can i do it?, What problems will i run into? 92BLKL98 03-26-2005, 10:49 PM I plan to do this but itis going to require some tuning to make it work. My interest is to work toward the LT1 intake mod. Randy92Z 03-26-2005, 10:57 PM You can remove it, but it will set a code, unless you have your chip re-programmed to have the EGR turned off. cc89formula 03-26-2005, 11:17 PM You can do like me, just rip it all off and then stare at that damn SES light.... LoudmouthSS 03-27-2005, 12:08 AM what bout block off plates and stuff?...yea i can care less bout that SES light lol cc89formula 03-27-2005, 12:33 AM yea i can care less bout that SES light lol Thats what I thought, but the whole way home it was just staring at me. I couldnt take it. LoudmouthSS 03-27-2005, 12:40 AM lol...yea true.. heh LoudmouthSS 03-27-2005, 01:54 PM besides getting rid of the egr...what else can i remove? Randy92Z 03-27-2005, 01:59 PM Air Pump that will free up some space and weight under the hood. Ditching the A/C will take it even a step further on space and weight. If thats what your looking for. cc89formula 03-27-2005, 03:27 PM heater too. But i like the ac and heater, mine are staying. LoudmouthSS 03-27-2005, 04:52 PM yea fl = hot...ac stays lol. But yea im just trying to clean up that jumbled mess under the hood. The engine is being pulled soon so im gunna clean everything up, repaint the compartment and scrap all the crap i dont need. So the egr and air pump...sounds good klumb15 03-27-2005, 06:32 PM switch to a carb..that cleans it up a bit ;) ...ac delete makes a huge difference, escpecially if you get the 1le box like i did...airpump delete also makes it alot easier to get to the plugs too...new intake i think is the biggest thing to make it look cleaner...stealth rams look awesome under the hood... LoudmouthSS 03-27-2005, 08:32 PM heh, yea i like fuel injection, so no carb for me. I was going to swap to a stealth ram upon reassembly. But yea the air pump and egr are deff gunna go. My a/c i believe works, but im not even sure<not charged> lol, if it doesnt..then bye bye. whats the 1lE? anthony714 03-27-2005, 11:16 PM why do you wanna rip egr off..first you aint going to see much of an increase if any..secongd it shouldnt set a light off cause an egr if i recall is only an output signal and that shouldnt set off light unless you unplug the electricall conector..just remove the egr valve or just unhook it and plug the vacuum line..the comp dont know if the vacuum line is unhooked as long as its plugged..what exactly are you looking to do?make horsepower?lighten car?go fasteR????? LoudmouthSS 03-27-2005, 11:58 PM actually..its just ugly and in the way, so i want it out of there. ANYWAY, where can i find some block off plates? cc89formula 03-28-2005, 06:42 PM I think Im just gonna make mine, but if you can find them cheap let me know Kevin91Z 03-29-2005, 12:26 AM why do you wanna rip egr off..first you aint going to see much of an increase if any..secongd it shouldnt set a light off cause an egr if i recall is only an output signal and that shouldnt set off light unless you unplug the electricall conector..just remove the egr valve or just unhook it and plug the vacuum line..the comp dont know if the vacuum line is unhooked as long as its plugged..what exactly are you looking to do?make horsepower?lighten car?go fasteR????? Yes, the computer does know if the EGR isnt working. The EGR is the only smog device the computer keeps track of. On MAF cars, there is a temp sensor in the EGR valve. When the valve opens, it will get hotter. On MAP cars, the computer checks for a change in the MAP when the EGR opens. LoudmouthSS 03-29-2005, 10:47 AM hmm...ok so Ill just be staring at an SES light..no big deal. I dont like my hypertech chip anyway, im gunna go to diablo tuning around here and get them to make me a custom chip, so that'll solve my SES problem billyhoss 04-01-2005, 12:31 AM iam going to remove my egr too and was wondering if i can remove that whole setup just under the coil and just plug the vac line that goes to the tb, iam thinking that when the ecm tells the egr to open it gets its vacuum pressure from the connection at the tb once that swtich opens up under the coil? anyone help me out? thanx | ||
