Geezer powered
03-24-2005, 09:03 PM
What would be the correct backspacing to fit a 18-10.5 rim with a 295 tire????????
18-10.5 ?Geezer powered 03-24-2005, 09:03 PM What would be the correct backspacing to fit a 18-10.5 rim with a 295 tire???????? KY95Z28 03-25-2005, 04:03 PM Ideally between +50 and +53mm, but you can go up to a +58mm with only some minor banging(aka BFH mod) to the inner fender wheel. I assume you are referring to the rear, as this is what this info pertains to. | ||
