disco192
03-24-2005, 02:44 PM
I posted this in LT1 tech earlier, but I wanted to hear some expert opinions on the matter. I wrote this to help explain why at home builds do not stand up to expectations set by professional builds.
Its all about attention to detail. There are alot of little things that will pull more power out of a motor than simply head flow, cam design, and bolt ons. There are things like quench and compression that can increase power. If you set up the motor to .032-.035 quench (.032 is close, but possible w/ hypereutectic pistons) it will make more power and let you run a bit more compression (there is also effective quench, but that a whole new beast involving metal expansion....).
Setting up the dynamic compression to the highest possible given the local octane available and weather conditions will net you more power. You can also squeeze more power if you use optimal ring gaps, or use a top ring gapless set of rings. It will seal better and pull more airflow out of the heads on the intake stroke as well as reduce blowby (this is usually pretty controversial, but im a believer).
Accurate balancing and running a lighter rotating assembly can also make some more power. You could also get some more power with a lighter valvetrain. If you use beehive springs with TI retainers (and maybe a good rev kit) and some lightweight valves, then it will minimize the valve bounce when it shuts (as well as reduce valve float). Then you have custom cams and assembly.
I think I am starting to ramble, but my point was that attention to the little details is what separates a quality professionally built engine from an engine that someone just throws together. Making power is all about understanding how the motor works and utilizing it.
Im sure there are other secrets that can make more power, but I cant think of them right now.
