Bronze or iron distributor gear
Tweaked Zed
03-24-2005, 02:37 PM
I heard that bronze oil pump drive gears don't hold up with high volume oil pumps. Is this correct? I have a new #8513 MSD oil pump drive with a bronze gear driving a Melling HV155, and just want to make sure I don't have any problems with it. Any body know? Thanks.
LT1 1980 malibu
03-27-2005, 07:48 PM
They dont hold up as long..Truthfully it wont do any harm when it goes out..The worst that has happened to me is that it got all chewed up and left me stranded for a few till i could get the trailer to me..If your cam requires a bronze gear then you really have no choice..Your other option is to run the iron gera and have iron chips killing your insides..Bronze gears are designed to wear out because of the cam being made from steel at the oil pump drive..
jonaddis84
03-27-2005, 08:27 PM
you do have another option, comp cams polymer distributor gear.
TCAL95Z
05-12-2005, 01:13 PM
What part number is the Bronze gear and where can I buy it?
My Joe O Solid roller cam requires a bronze gear.
Tom
1racerdude
05-12-2005, 08:43 PM
Crower makes the longest wearing bronze gear on the market.
SABLT194
05-13-2005, 05:46 AM
What is the gear in a stock LT1 made of?? I'm about ready to bolt up the intake and I would like to know if I need to swap gears for my HV pump.
Steve
1racerdude
05-13-2005, 12:47 PM
Steve
Ya don't swap gears for the pump,it's if the cam is compatible.
TCAL95Z
05-13-2005, 03:22 PM
You are the man. I should have just emailed you to begin with.
If I call Crower is there a certain part number to ask for? I know there is a certain size opening that is needed.
How long do these gears normally last?
Thank you,
Tom
1racerdude
05-13-2005, 03:43 PM
Thank you,
Tom
Talk to Dave Crower and he will plumb you up on which one.You will have to have the shaft size to get the right one.
I have run them better than 2 yrs and still good.
TCAL95Z
05-13-2005, 10:41 PM
Thank you
1racerdude
05-13-2005, 11:05 PM
Thank you
Anytime.
