Camaro_Boy
03-24-2005, 02:21 PM
i swaped my auto 86 camaro to a manual transmission.. everyhting is perfect... one thing... i used the wiring harness from the auto and broke off hte unit so the car would start.. do i have to buy a new wiring harness or how down i make the car go into reverse... ie... the lights for reverse arent turning on.. how do i make the car go into reverse without havent to put in a switch?
regards..
Douglas
respectirocz
03-24-2005, 02:42 PM
the wiring harness for the auto trans should have 2 wires, a power and ground for the reverse light for when the auto tranny shifts into reverse, u can hot wire em to work with the manual tranny
if u dont know which ones are for the reverse maybe u could try just putting them together one at a time till the reverse lights turn on and stay on
Camaro_Boy
03-24-2005, 02:45 PM
ok perfect.. so as for the reverse i can figure out which one is which... but how do i get it so when i put the car in reverse the lights on it? some sort of switch i guess??? im not to sure? thanks again
DOuglas
Randy92Z
03-27-2005, 11:01 PM
On the side of the manual xmsn there should be a 2 prong connector, that is your back up switch
Camaro_Boy
03-29-2005, 01:21 PM
so i need to go get a manual wiring harness then correct? or?? dou h ave any pics or anything to help me along..
regards
Douglas
Randy92Z
03-29-2005, 01:29 PM
First off, what tranny did you put in? Was it a T-5, T-56?
Camaro_Boy
03-29-2005, 01:58 PM
that is a good question.. i have NO idea.. it came outa a firebird i heard.. and thats all i know..
Tru2Chevy
03-29-2005, 02:40 PM
Is it a 5 speed or a 6 speed? Did it come from another third gen? Did it come from a 4th gen LT1 or LS1?
- Justin
Camaro_Boy
03-30-2005, 09:52 PM
5 speed. came off of a 1985 camaro rs i believe. thanks
C Murda
03-31-2005, 12:02 AM
yes go to your nearest GM dealership and ask for the T5 Reverse light wireing harness...should be a simple female style plug that goes right into your tranny reverse light connector. from there all you do is wire your exisitng wires to this harness. enjoy your "new" car
Camaro_Boy
03-31-2005, 12:04 AM
do i get this connector? and then i plug in the reverse cable to the tranny? the sensor or whatever it is on the side of the transmission under the car?
thanks alot for the help btw
app it alot
Douglas
