Track Results
Old Oct 13, 2002 | 04:39 PM
LBJ's Avatar
LBJ
Track Results
Just got back from the track and got a new best.
13.21@106.7 (no power shifting)
60' 2.16
Iam very happy with this car. Ive only had it for 5 weeks and I know my times will keep dropping with a little more practice.
Old Oct 13, 2002 | 05:17 PM
Drew778/94Z's Avatar
Thumbs up
WOW, all you need is a Lid and to power shift and you should be in the 12's.
Old Oct 15, 2002 | 07:49 PM
LBJ's Avatar
LBJ
Thats a good point. I was thinking by just adding some nitto DR's I would be able to pull some 1.90's or maybe some 1.8x's to break into the 12's!
Anyone have thoughts on that???
What rpm would I have to launch @ to get 1.8x's or 1.9x's??
What rpm is safe to launch @ without beating the hell out of the tranny?
Old Oct 16, 2002 | 12:14 AM
96SFLZ's Avatar
Nice times, DRs should get you a sub 2.0 60' and that should put you very close to 12s. At a good track (good prep) you could pull a 1.8x 60' and that should definitely put you into the 12s.
On DRs I would launch somewhere around 3000-3500.
Old Oct 16, 2002 | 02:52 AM
Rd95Z's Avatar
Good times!
Powershift, throw some DR's on, get that 60 ft. down and you'll be very, very close to 12's. Don't worry about blowing the tranny, you're not making enough hp to worry about that. Definitely look into a lid or some sort of intake/lid... then work on getting some sort of a cat-back.
Good Luck!
-John
Old Oct 16, 2002 | 08:11 AM
dohcsvt's Avatar
Yeah, don't worry about the tranny, however no one happened to mention the rearend in these cars are severe POS's. Be careful of hard launches on sticky tires!!! rearend may go BOOM!
Old Oct 16, 2002 | 08:19 AM
Lt1 and Ls1's Avatar
WOW! That is GREAT! Keep up the good work.
Old Oct 17, 2002 | 10:41 AM
LBJ's Avatar
LBJ
OK! Went to the track last night and ran....
13.09 @ 107.2
60' 2.06
Very happy with that time, I also ran a 2.04 60' but missed 3rd!
Maybe that could have been the 12.x slip I sooooo badly want.
NEXT TIME!
Old Oct 17, 2002 | 01:59 PM
psychocabbage's Avatar
very nice. we have cooler weather here now.. I will see if I can beat those! :P
Old Oct 17, 2002 | 02:13 PM
k9pusher's Avatar
awesome time! I just bought my car (see below) and am planning some mods for next week...hopefully I can break into the 12's soon as well, but it will probably take me a while...I have never run on a track...
Old Oct 17, 2002 | 07:20 PM
why add mods when you dont know if it will hit 12's stock?
Old Oct 18, 2002 | 12:35 AM
XKnightRider's Avatar
Talking
Nice times, if you go with DR's you may want to consider a T/A cover with stud kit this will add a little beef to your rearend so you don't blow it.
I just went to the track with my DR's for the 1st time, they hook so well it bogged the motor even at 4500 RMP launches. I had some tuning to do as well. But I was able to cut a 1.9 60' time, but on that run I didn't powershift so I only ran a 13.01 and the MPH was broken and said 124MPH
Old Oct 18, 2002 | 12:38 AM
Oh yeah...if you do hit 12's you'll need a drive shaft loop to be track legal. In other words if you are tech'd for 13's and you hit a 12 that will be the end of your night unless you have a loop. But that may be just what you want!
Old Oct 18, 2002 | 02:30 AM
k9pusher's Avatar
well good point, but I have not seen an ss conv. running 12's stock? all I have seen/heard says mid 13's if you nail it
Old Oct 18, 2002 | 06:48 AM
why you launching so high?
Wouldnt you want to launch closer to 3000 or so.. about where your torque peaks so that you hit the most torque you can... Thats what I would figure... hmmmm.. 1.9's on DR's would be upsetting..
