95Z28QFZ
03-19-2005, 09:16 PM
I have a 95 z28 great condition. Everything on the outside is new. spent 5200.00 on the paint and trim, the paint is red with painted on black raceing stripes with red pearl in the black. when the sun hits the stripes just right it looks somewhat like red flake. 1800.00 wheels and tires, motor has 70,000 on it with new water pump and opti. new plugs and plug wires all new sensors. true duals with h pipe and 2 2 chamber flowmasters. drivetrain is good with no leaks 3.23 gears. the transmision maybe on its way out again. Car pulled 306hp and 360ftlbs of torque on the dyno. Inside the car is in good shape black leather seats kenwood stereo with factory bose speakers. If interested I can e-mail pictures of the car.
AK5 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU0 LOCK CONTROL, REM0TE ENTRY
A31 WINDOW, POWER OPERATED, SIDE
A90 LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B35 COVERING, REAR, FLOOR MATS CARPETED INSERT
B84 ORNAMENTATION, EXTR MLDG, B0DY SIDE
C49 DEFOGGER, RR WINDOW, ELECTRIC
C6G GVW RATING, 7600 LBS
DG7 MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DL5 DECAL, ROADSIDE SERVICE INFORMATION
FE2 SUSPENSION SYSTEM, RIDE HANDLING
FE9 CERTIFICATION EMISSION, FEDERAL
GU5 AXLE REAR, 3.23 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
IFD TRIM, INTERIOR DESIGN (FD)
JIF BRAKE PROVISION SPECIAL TO SUIT FOREIGN REGULATION
J65 BRAKE SYSTEM, POWER, FRONT AND REAR DISC
KG9 GENERATOR, 140 AMP
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
LT1 ENGINE, GAS, 8 CYL, 5.7L, MFI, HO
MXO MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
M30 TRANSMISSION, AUTOMATIC 4 SPEED, 4L60E, ELECTRONIC
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NP5 STEERING WHEEL, LEATHER WRAPPED
NW9 TRACTION CONTROL, ELECTRONIC
N96 WHEEL, I6 X 8, CAST ALUMINUM
QFZ TIRE ALL, P245/50ZR16
STE PLANT CODE - ST. THERESE, PQ, GM OF CANADA
T96 LAMP, FOG
UB3 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM,
U1T RADIO AM/FM STEREO SEEK/SCAN, COMPACT DISC, HPS, CLOCK, ETR
U63 RADIO, AM, MTR U64 SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL STD RGE
U73 ANTENNA, FIXED, RADIO
VK3 LICENSE PLATE, FRT MOUNTING PKG
VM3 LABEL, CONSUMER, CONTAINS BPR IMP STANDARD
V73 VEHICLE STATEMENT, USA/CANADA
Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY ORDER MODIFICATION STOCK
1SA OPTION PACKAGE 01
12I INTERIOR TRIM, GRAPHITE (92)
122 TRIM COMBINATION, LEATHER, GRAPHITE (2) (92)
81Q MOLDIMG COLOR, BRIGHT RED (9
81U PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
weight 3500 pounds
T96 LAMP, FOG
weight 3500 pounds
