hozb817
03-18-2005, 12:14 PM
Just wanted to know how to fit a set of slicks and skinnies. I tried to mount the fronts and the wheel was to tight of a fit, maybe cause the F Body was designed for 16in rims. I herd of grinding down calipers? How could I do that? What tools would I use? Does it ruin the calipers? Any helpful information will be appreciated. Thank You ~ hozb 817
Injuneer
03-18-2005, 02:42 PM
I have experience with the Weld Pro-Stars.
Front:
You need a 5/16" spacer to clear the spring clips that hold the pads in the calipers, and the big horizontal arms that the calipers rest on. Also requires longer studs to meet NHRA tech.
Rear:
Grind the fins off the caliper. Doesn't hurt them. See picture.
http://cjcfo.fbody.com/members/injuneerzz@aol.com/PhotosM/DCP04016a.jpg
