94 V6-V8 conversion
Project94
03-17-2005, 09:36 PM
Wondering what will need to be replaced so the LT1 is functional. Its my buddy's car, the little 3.4 isnt enough testosterone substitute. If ya'll could develop a list of what to replace, that'd be awesome.
dtrsam
03-17-2005, 10:08 PM
I swapped mine 95 3.4 to 97 lt1 heres what it takes.
COMPLETE LT1 W/ACCESSORIES,SENSORS, COMPLETE FRONT WIRING HARNESS
PCM
K MEMBER
ENGINE MOUNTS
TRANSMISSION
TRANS. MOUNT
RADIATOR
FANS
FUEL PUMP
FRONT FUEL LINES
CROSSMEMBER
DRIVE SHAFT (1PC)
SHOCKS
SPRINGS
EXHAUST (MANIFOLDS OR HEADERS)
Y PIPE
THESE ARE PRETTY MUCH WHAT IT TAKES TO GET IT IN AND RUNNING, YOUR BEST BET IS TO FIND AN LT1 OUT OF A 94 SO THAT IN CABIN WIRING WILL MATCH UP WITH THE UNDER HOOD HARNESS OF THE LT1. OTHER WISE YOU WILL BE SPENDING A COUPLE OF DAYS MATCHING UP THE 2 DIFFERENT HARNESSES. A GREAT SOURCE FOR WIRING DIAGRAMS AND CONNECTOR PINOUTS IS WWW.ALLDATADIY.COM
ID BE GLAD TO HELP WITH ANY QUESTIONS OR PICS IF NEEDED :cool:
Project94
03-17-2005, 10:32 PM
Thanks man, keep me informed! We found a site that has a lot of info on it too: www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm Do you agree with the statements made on that site? Oh did yours have the ASR/Traction control system?
dtrsam
03-18-2005, 05:38 PM
TA CREATIONS HAS SOME GOOD INFO ON THE SWAP. MY CAR HAD ABS BUT NO TRACTION CONTROL, IF YOU USE AN LT1 THAT IS THE SAME YEAR AS THE CAR THEN THE ABS IS SIMPLY PLUG AND PLAY (YOU WILL PROBABLY HAVE TO GET THE INOP LIGHT TURNED OFF BY A DEALER, iT WILL COME ON AFTER YOU BLEED THE LINES) OR JUST DO LIKE I DID AND GET RID OF THE ABS.
IN CASE YOU DONT KNOW THE BEST WAY TO PULL AND INSTALL THE ENGINE IS THROUGH THE BOTTOM. YOU CAN LEAVE ALL ACCESSORIES, HEADERS, ECT INSTALLED, SAVES A LOT OF WORK
I CAN PULL MY ENGINE AND TRANNY NOW IN LESS THAN 2 HRS.
HERES A GOOD LINK WWW.MICHIGANSPEED.COM/ENGINEPULL/INDEX.HTML
Injuneer
03-19-2005, 12:24 AM
This belongs on "LT1 Engine Tech", or on "V6 Tech".... tell me which you prefer so I can move it there.
